I have a slow leak coming out by the pressure release valve on my boiler. I'm trying to isolate whether it's the valve or the expansion tank (Amtrol -- or Extrol -- model #30). Could be other issues, I suppose (I'm obviously clueless), but I'm focusing on those two for now.
The leak happens when the system is operation. I turned off the thermostat and cut the water supply to the boiler and the leak stopped. There was water still in the pipes leading up to the release valve, of course, but it still didn't leak. When I turned the water and thermostat back on, there was a lag before it started leaking again...I'm estimating the lag was 1/2 hr to an hour.
Can anyone suggest to me specific steps I'd need to take to isolate the problem? I know I'll have to check the pressure. On that note, I do not have a pressure gauge near the expansion tank; the only pressure gauge is on the boiler itself. Maybe this is the pressure gauge I need to look at. Don't know. But, so far I haven't taken note of the pressure (I know I'll need to do that and will do so tonight).
Also of note -- I had had the whole system drained because I was working on fixing walls behind my radiators. The system was empty for approx 5 months.
Any assistance you can offer is much appreciated. Please do ask for clarifications if you need any.
Thanks, Mike
Thanks, Mike
