I was at a client today to check his heating for fall and took a look at the water heater I replaced about a year ago. Both the hot and cold water copper lines that I had redone were already black. I began looking around and the copper lines to a/c unit are black. The cold water lines are not only black but they are flaking this stuff that kind of looks like graphite when you take some off and rub it between your fingers. The same with new water lines to humidifiers I ran a couple years ago.
The home is too old for the chinese drywall fiasco but that does not mean it is not something similar going on. It's BAD! FWIW the 40' of 1/2 bare copper in his garage going to an outside faucet only has the typical discoloration old penny look that you would expect after 40 plus years. I'm pretty sure I remember the blackened copper from last time I was there but I'm sure I would have noticed that massive flaking issue.
The bright copper is part of the water htr return loop.
Well water with softener and iron removal, no cats, no strange smells, 90 plus PVC vented furnace, tank is not spilling...
Can't tell from this bad photo but that black copper is covered with flakes.
So?
Thanks
So?
Thanks
