Additives for Septic System
Asker123
Manitoba
Not sure which forum to post to so trying my luck here.
We are on Septic Tank and Septic field system.
Septic tank is fiberglass based. around 3 feet diamieter riser going down around 6 feet and then there are two chambers in a circular portion. Around 3/4 is solid side and 1/4 is Liquid ( Grey water) side . A baffle between the two.
Septic pump is inside the house only the ball hanging in liquid side in the tank. Pump pumps grey water to a Septic field ( Leach field) approx 100 foot backside of house.
I got the tank cleaned last week and now thinking of the following product.
Roebic K-570 32 Fl. Ounce Biodegradable Leach and Drain Field Opener Concentrate​
It contains aerobic bacteria and enzymes.
Rather than flushing in toilet, will it not be good idea to directly dump in the liquid side of the septic tank? That way it wont go to the solid side and directly reach to drain field through the pump.
I am not having any issue as such. Just trying to take precaution . There have been some sludge in the liquid side of the septic tank which might have gone to the drain field . I heard that the sludge creates Biomat or something. Septic tank has been cleaned annually for last 4 years
My idea is to add the solution as close to the drain field in the system and to avoid adding to Solid side of the tank.
Anyone has any idea? or can direct me to some other forum. Thanks in advance.
