Jsmallberries
This AAV/trap piping was inside a bathroom vanity, I've never seen this before in my neighborhood, same tract homes built the same time, this is the only one without behind the wall venting pipes, that exit through the roof.
The new vanity has drawers and the current set up is in the way. The back of the vanity is open except for a few vertical supports.
Can I come straight up inside the wall and add the AAV at the top with the p-trap pipe through the wall, and add a recessed box with a grill for the AAV. The recessed box/grill will be open to the inside of the vanity since there is no solid wall at the back.
Would this be acceptable? If not, any other ideas?
The other question about this: Above the angle stops, there is a 3/4" piece of pipe that goes straight up, about 18", from the 1/2" CPVC, and is capped. I suppose this is to deal with "water hammer"? Or at least how they did it 25 years ago. Had to repair one side and put it back how it was. Correct assumption and does this work to lessen the impact of water hammer?
