pilot4net2
- Messages
- 9
- Reaction score
- 0
- Points
- 0
The first question is this: Do you use PVC or CPVC for the hot water supply lines? I heard somewhere someone referring to the CPVC as "hot water pipe" and was wondering if I had to use CPVC or if I could use regular PVC. Next...
I was at a friends house the other day and he is thinking of doing some renovations including some plumbing. I looked at the piping in his house and it is some kind of tubing I've never seen before. It was a clearish white pipe/tubing that connected to fitting using a brass ring that looked like it crimped the tubing to the fittings. It really looked like a poor choice of plumbing materials but it may very well be because I haven't the slightest idea what it is. What kind of tubing is this and does it provide reliable and leak free water supply? Also, how do you make connections to this tubing using the "crimp ring"? Is it something a DIY'er can do successfully? Please let me know all you can on this kind of plumbing and how to make connections using this material. Thanks.
