| Posted by Sylvan on August 04, 2004 at 17:26:22: | |
| In response to Re: Toilet Flange to Cast Connection | |
: This is on a Concrete Slab, if that helps. Exactly just like concrete roof drain applications where all work has to be performed from on top CAULKED is the best and easiest way out. Cut around the existing piping set the caukled flange put in oakum and in one pouring fill with molten lead to a thickness of 1" lead Then caulk, trim and never have to look back. |
| There are none. |
