| Posted by jimbo on July 26, 2004 at 11:02:14: | |
| In response to Re: Re-routing drain line out of soffit into wall | |
: If you are dealing with ABS pipe this technique has a high success rate. I wouldn't even try it with PVC. They make drill bits(reamers) to cleanout the fitting, but it sounds like you are at the wrong end of the donkey for this to wotk. |
| There are none. |
