| Posted by hj on June 16, 2004 at 00:01:05: | |
| In response to Re: Replacing unused solid concrete tub (extended question) | |
The drain will always dry out unless water is run in the tub about every two weeks, or a non evaporating antifreeze, or other liquid, is poured into it. : Following on my original question: If the tub is never used, is there any danger/concern related to the drain drying out and allowing venting into the living space? : Comments and advice will be appreciated. : : Jim Wingo - Orlando, Florida
| There are none. |
