| Posted by LonnythePlumber on June 10, 2004 at 13:34:45: | |
| In response to Re: How to Cap a 1/4" copper tube? HELP!!!! | |
: : The right way is to find where the tubing connects to the supply line and deal with it there. : ::::If i couldn't get to the supply area I would crimp the tube a couple of times and sweat the end with solder. They do it on freezer and fridge copper lines so I don't see why it wouldn't work in your situation. A 1/4" compression stop will provide temporary relief. If cutting a hole in the ceiling will provide access then that is what you should do. It is probably only a matter of time until it starts leaking at the valve pipe connection. LonnythePlumber |
| There are none. |
