PEX rough-in
Posted by Henry on June 03, 2004 at 13:26:52:
I'm planning to use PEX for new construction. Anyone have experience with this material?
Two questions:
1) is 3/8 pipe adequate for supply with a manifold system?
2) how do you rough-in copper stubs? Everything I read says solder before you crimp the PEX, but it seems you would have to crimp to the stub-out, then solder a fitting AFTER drywall is up.
Replies to this post
There are none.
