Re: Turning a toilet 90 degrees
Posted by hj on May 31, 2004 at 21:44:26:
In response to Re: Turning a toilet 90 degrees
You might be a candidate for an Eljer "Triangle" model toilet. The ideal measurement for it is 12 x12, but since you have 12 x 13 it will just be an inch farther away from one side than it is the other. If your flange has a metal ring that can be rotated the conversion is simple.
: I have just put in a small half bath and the front of the toilet is quite close to the vanity. I knew it would be close but for anyone over 6 feet or so, it may be kind of tight when sitting.
: Can I turn the toilet 90 degrees without removing the flange from the closet bend? Is there an adapter to do this with or am I faced with removing floor and cutting off bend and installing new?
: FYI the current flange is 13 inches from one wall an 12 from the other.
Replies to this post
There are none.
