| Posted by Sylvan Tieger on May 29, 2004 at 23:55:59: | |
| In response to Re: About to start digging cast iron sewer line up...*H*E*L*P*! | |
Good luck to all on your up coming wedding. With the PVC (Crap) be very careful on the bed it is laid NO ROCKS and no traffic above this crap pipe as PVC has little strength as far as load bearing goes. I am not totally against plastic if soil conditions warrant this type of cheap job. I just feel if given a choice I would personally use Extra heavy or even No Hub cast Iron rather then plastic under ground. See this article Shows IM not against plastic http://www.masterplumbers.com/plumbviews/2000/copper-vs-pvc.asp |
| There are none. |
