| Posted by Sylvan Tieger on May 05, 2004 at 16:36:29: | |
| In response to Re: Finally called 3 plumbers | |
: and they all had a different solution to replace the galvanized pipes under the second floor bath.The bathroom has a tub sink and now a washing machine and dryer and one of the plumbers said they could run a 2 in pipe that would handle all three ..that didnt sound right..and the other 2 had soultions that were totally different.My question is isnt that against any code? Thanks Jon Depending how much room you have I personally would go for a 3" line BUT if you have to use 2" try to have the washing machine connect through a wye far down stream as possible to keep sudsing to a min Another factor governing FU's Is PITCH and try to go with No hub cast iron rather then plactic as CI you can use long sweeps allows much better drainage and a quiet safer system |
| There are none. |
