Re: Installing a washer/dryer in an apartment-style condo
Posted by Gary Swart on April 29, 2004 at 20:44:28:
In response to Re: Installing a washer/dryer in an apartment-style condo
Better go for professional advice here. A standard washer requires a 2" drain because the volume of water discharged per unit of time is much greater than any other fixture. There may be some smaller apartment sized units that will work, but you need to have solid advice from a person on site. You never should do any plumbing in an apartment or condo on your own. If something should happen that damaged other property, you would be held liable.
Replies to this post
There are none. |
