Message for Deb.. the pipe godess
Posted by Vince on April 02, 2004 at 08:54:17:
In response to Message for Deb.. the pipe godess
Deb: I have read your posts over the last couple of years on different boards. You know what you are doing and it shows. However, your under UPC as was I until just recently. I'm now under IPC. Running the T&P outlet outside is a great idea, but there needs to be an air gap fitting installed at the tank so a person checking the tank can see if the T&P is leaking. UPC does not address this unless it is in coding after 2000. Keep up the good work
Replies to this post
There are none. |
