Toilet Flapper w/Float
Posted by Cyndi on March 30, 2004 at 11:09:12:
I still need your HELP. I have a Kohler Wellworth 1.6 toilet which had phantom flush. I installed a Kohler Red Adjustable Flapper PP23648, which is what the hardware store suggested, and thought the Phantom Flush was gone, but it is still there, just not every 5 minutes as before. There are little air bubbles all over the flapper, float, and lower chain (the parts that are under water). I did lower the float, as you recommended, so now the flapper opens longer and the flush is better (THANK YOU). But it still is doing the Phantom Flush. Is there anything I can do--any adjustments I can make--to fix it. Is there a different part that I should use (and if so, how do I know what to get?) Please bear in mind that I know nothing about plumbing and can't afford a plumber right now (since I'm unemployed). Any help you can give would be greatly appreciated! THANK YOU!
Replies to this post
There are none.
