| Posted by hj on March 30, 2004 at 08:44:07: | |
| In response to Re: How do you adjust a toilet flapper w/float? | |
It may also triple flush, but since most customers do not like the poor flush with a single flush, they usually actually enjoy the additional flushing since it implies that it is working better. : : It is usually a good idea to use identical replacement parts; the Kohler Wellworth and other models do come with a float on the chain. There is a little clip on top and bottom side of float which you can pull off the chain, move the float down (for longer flush), then replace the clips. : A "standard" low-flush flapper will work, but because the Wellworth is a much deeper tank than some others may cause the toilet to double flush do to flapper staying up too long.
| There are none. |
