| Posted by Sylvan Tieger on March 28, 2004 at 16:15:19: | |
| In response to Re: Lavatory drain clogged | |
: I had a lavatory backing up after about a quart of water ran in. Trap was clear. Tried using a flexible snake. Hit what I thought was the Tee and was far as I could go now it won't drain. What's the best way to c Glad you menthioned lead piping. Many of my accounts are building built in 1922 and lead pipe is the noem for drainage. The best thing to use is either a STRONG wet dry to suck the debris out like a Sear 5 or 6 HP Or a General RAM jet no more then 40 PSI. either one you use is good BUT remember to hold a rag over the over flow and DO NOT EVER USE CHEMICALS |
| There are none. |
