| Posted by John Arthur on March 20, 2004 at 22:46:59: | |
| In response to Project completed | |
Found everything I needed at the local harware store. The longest dryer Gass line they had And a 24' sump pump hose that looks remarkable simmilar to the exit hose that came with the washer. So close that I tried to hook it up to the pump itself, but the original line was cemented into a rubber hose. In the end, I conected the two hoses together at the smooth flared end of the sump line using latex silicon sealent and a hose clamp. This is working perfectly, and even if it dose leak, it is directly over the sump. Total cost was less than $90.00 Now to hand a pair of those nice Melamine cabinets, and a new light. Thanks alot : Should be no problem as long as you can find hoses that long. : : I am moving my washer 90" away from the current standpipe. Can I just extend the hose along the wall till I get a new stand pipe put in?
| There are none. |
