waterlogged pressure tank
Posted by angela on February 16, 2004 at 12:42:45:
I have a well system, Bruke pump (visible), a Square D pumptrol 20/40 pressure switch, an old galvanized pressure tank (no pressure gauge), the only valve is at the bottom of the tank (no shut off valve), no leaks detected in the pipes. I rocked the tank and heard water at the top. What caused the tank to water log and how can I fix it? Will replacing the galvanized with a bladder tank solve the problem? Should I replace the pressure switch at the same time? I would like to do the work myself so any guidance is greatly appreciated. Thank You, Angela
Replies to this post
