Re: my well makes noise when it cuts off
Posted by Hube on February 13, 2004 at 18:36:33:
In response to Re: my well makes noise when it cuts off
: when the water reaches the high setting there is a squeal when the pump cuts off. there is also a small jump in the pressure when it stops. Please help I have not been able to find a plumber to answer my question. Thank you For your time.
The slight "jump in pressure could be the Check-valve closing no problem. ,...You dont say if this is a sub or a jet pump. I will assume its a JET, it could be a bad bearing causing the impeller to bind when the there is no strain. Hube
Replies to this post
There are none.
