| Posted by ED on February 05, 2004 at 18:54:18: | |
| In response to Re: Moving a basement toilet drain over a few feet... need help! | |
You do not want to overslope that pipe. It should slope no more than 1/8 to 1/4" per foot for a three inch pipe, for example. Otherwise the water will flow quicker than the solids and create a potential clog with the solids left behind. A real possibility with some of the 1.6gpf toilets if people use a lot of toilet paper. I will add there's a constant debate going on about this slope issue amongst plumbers. : : I am completely refinishing my basement (gutted it out and starting from scratch). The design of my new larger bathroom (there was an existing bathroom) requires me to move the toilet drain to the left about 3 feet. The existing toilet drain goes straight down for about 24" and then bends out to the wall and into the back yard where I presume it meets the sewer line at some point or joins my main house line. I want to move the toilet to the left, and my question is how deep should the new pipe go straight down before it goes to the right to join the old pipe? Can it just immediately elbow to the right as long as I use the 1/4" per foot slope? I could actually have quite a bit steeper slope if that is better but I read that 1/4" per foot was the minimum. Also, can I just cap off the existing pipe above where my new pipe joins it? : You need a vent in there somewhere.
