| Posted by Rford on January 23, 2004 at 15:56:31: | |
| In response to Re: Can I drain Urinal into clean out on stack? | |
: : I'd like to put a urinal in my basement for occasional use. It seems to me that the easiest way to do this would be to run the drain line into the clean out on the waste stack. This is a fully accessible area and so if I ever need to use the clean out to actually snake the system I can just uncouple the urinal piping and snake away...any reason I can't do this? : : Thanks Thanks Deb---I think I can overcome the water line and the vent....I have a 3/4 line and can't I use those Oates valves? As far as the threads...couldn't I take a PVC threaded plug, cut a 2" hole in it, and use that as the connection point? Thanks
