Re: Delta monitor shower valve-How to get at spring
Posted by e-plumber on January 02, 2004 at 16:24:38:
In response to Re: Delta monitor shower valve-How to get at spring
: I have removed the handle in order to get at the seats and springs since their is a constant drip from the spout. I can't get the next piece off to get at the spring.
Reply:
Your best bet is to soak it with WD40, let it sit for a while, then try again. I have had some nuts that hold the cartridge in on a Delta Monitor seem like it becomes part of the valve body. Try to tighten it slightly to free it up, then unscrew it.
Good Luck. e-plumber
Replies to this post
There are none.
