| Posted by hj on December 05, 2003 at 21:14:14: | |
| In response to Re: pvc flange where floor meets toilet broken | |
An experienced plumber should be able to remove that flange and install a new one. I would hesitate to suggest that you try it given you low frustration level. : The pvc flange where the floor meets the toilet is broken. It is broken where the slot for the screw went on one side. We plan on puttin tile in this bathroom if this makes fixining the problem any easier. What is the remedy for this problem. I hope that it is easy since I broke the thing just ripping te toilet off the floor out of the frustration of not being able to undo a rusted bolt. Thanks in advance.
| There are none. |
