| Posted by Deb on December 02, 2003 at 18:49:42: | |
| In response to Re: Flexible vs. rigid copper tubing | |
: I need to run some plumbing in the floor, cutting through several joists. I don't want to notch out and lay in rigid pipe, nor do I want to sweat several 12" sections together with all those unions. : I was thinking I would use flex tubing. I would need it to handle 3/4" supply lines (both H and C) as well as a 1/2" run for the reciriculating line. : Anyone have an opinion? Ever had to do something similar? : Thanks, Matt What are you talking about here, plastic water line like Pex or CPVC or soft copper? |
