Re: Nightmare dishwasher installation... help!
[ Follow Ups ] [ Post Followup ] [ Terry's WWWBoard ] [ FAQ ]
Posted by e-plumber on November 18, 2003 at 20:09:10:
In Reply to: Nightmare dishwasher installation... help! posted by James on November 18, 2003 at 19:31:36:
: Hi,
: We recently installed a new Bosch (SHV6803) dishwasher and had a nightmare time with it. First off, after installing it with the air gap draining into a new In-sink-erator disposer (yes, I punched out the seal!) , the water positively gushed out of the air gap (no gentle trickle). Everything is new so there are obviously no clogs or build-up, the drain line is straight without obvious crimps or low-spots... I'm at a loss! Please help. I am so fed up with it, I am seriously considering scrapping the whole air gap idea.
: The second problem we encountered has to do with the actual dishwasher... the spray arms don't spray. I switched it on, it fills with water and hums along, then finally drains, but no spray! Is there something obvious I could check before calling out a professional? This is the first time I've encountered a new dishwasher not working and we splashed out on a top-of-the-line Bosch as well!!
: Thanks.
: James
Reply:
The air gap could possibly be installed backwards or the air gap could be defective if the inlet & oulet hoses are connected correctly.
I would suggest having a Bosch authorized repair technician service the unit. If you didn't void the warranty yet, you will if you attempt to repair the unit yourself.
Good Luck. e-plumber
Follow Ups:
Post a Followup
Name:
E-Mail:
Subject:
Comments:
Optional Link URL:
Link Title:
Optional Image URL:
