Re: Leaking Kitchen faucet
[ Follow Ups ] [ Post Followup ] [ Terry's WWWBoard ] [ FAQ ]
Posted by e-plumber on November 16, 2003 at 19:30:13:
In Reply to: Leaking Kitchen faucet posted by A Modi on November 16, 2003 at 19:12:01:
: I have a PricePfister single handle Kitchen faucet. It's been leaking under the sink. To open the faucet from top, there is a 3/32" ALllen wrench required to take off the plastic nut that's holding the handle. It was little hard to unscrew it when I tried to take it off, and I ended up stripping it in the process!! Now , How do I take the Handle off?
: Any reply will be helpful
: Thanks
: Ashok
Reply:
Are you sure your tool is not stripped, try a new allen wrench. Another thing, if the leak was below the sink, did you check to see if the leak could have been repaired under the sink?
If the screw doesn't come out, you may need to consider installing a new faucet.
Good Luck. e-plumber
Follow Ups:
Post a Followup
Name:
E-Mail:
Subject:
Comments:
Optional Link URL:
Link Title:
Optional Image URL:
