Re: Toilet leaking around wax ring/flange
[ Follow Ups ] [ Post Followup ] [ Terry's WWWBoard ] [ FAQ ]
Posted by LonnythePlumber on October 28, 2003 at 03:06:39:
In Reply to: Re: Toilet leaking around wax ring/flange posted by So. Cal. Plumber on October 28, 2003 at 00:18:42:
: : I give up!!! I have replaced the wax ring 3 times now, and it still seeps water out on the floor, i even installed a new mounting flange, when i initially replaced the toilet. I am going to try to fix it one more time, before i call in a pro, so any suggestions would be appreciated.
: First set the wax on the flange not the toilet. Second when setting the toilet over the wax, it needs to squish the wax down. If you don't feel the wax when setting the toilet you need to add an additional wax onto the first one. Another way to tell if you need a second wax is if the flange is at all below floor level. If it's flush it should be OK. If the flange is 1" or more above floor level it will squish out too much wax and not seal and needs to be lowered.
Are you sure it's not your tank to bowl connection running down on the floor? LonnythePlumber
Follow Ups:
Post a Followup
Name:
E-Mail:
Subject:
Comments:
Optional Link URL:
Link Title:
Optional Image URL:
