Re: slow toilet leak
[ Follow Ups ] [ Post Followup ] [ Terry's WWWBoard ] [ FAQ ]
Posted by Hube on October 20, 2003 at 16:21:47:
In Reply to: slow toilet leak posted by vgp100 on October 20, 2003 at 14:01:43:
: I have a slow leak coming from the underside of the tank. It's coming right from the large bolt that goes through the bottom of the tank. Will I need to replace the bolt and washer, or could it be something more serious?
You might try tightening a touch more, but if not, replace bolts etc.
Unless the tank is cracked, you can replace the bolt ,nuts, and washers. Most hardware stores stock these as a kit pair. Shut toilet supply valve off, drain tank, remove old and install new bolts ETC. Tighten uniformly. DO NOT overtighten. Put some water in tank and check for leaks. If ok, then turn valve back on, good luck, Hube
Follow Ups:
Post a Followup
Name:
E-Mail:
Subject:
Comments:
Optional Link URL:
Link Title:
Optional Image URL:
