| Posted by Kathleen Burridge on October 08, 2003 at 22:56:52: | |
| In response to Re: Toto toilet - water running (G-max flushing system) | |
How do you clean the fill valve works? My water turns off eventually... It stops and starts repeatedly. What do I do... ?
: : : My toilet keeps running. Water fills up, in tank, past overflow hole and doesn't stop. Is there something I can do to the flushing system, or should I just replace it? I've never seen this type of flushing system (G-max) that doesn't have a floater. : I had a similar problem with a Toto toilet. I went to a local plumbing outlet that handles Toto, described the problem and he gave me replacemet control unit - free. Their warranted for 5-10 years. I replaced the unit and it still cycled - the real probleem was the seal on the flapper $1.25.
| There are none. |
