Posted by Terry Love on September 27, 2003 at 22:08:51:
In Reply to: Confused about Supply Fixture units and minimum pipe sizes posted by Confused1 on September 27, 2003 at 21:21:01:
: I've unfortunately come to the point in time that I've been trying to put off forever. I live in FLA and have copper pipe in my 13 year old house. Most of the homes (some even newer than mine) have already been repiped, mostly with CPVC.
: Yesterday, I noticed water running out from under the slab step in my my garage onto the the main garage floor. This has me worried that the most likely thing going on is a leak in the slab and not in the wall. Therefore, it won't be a fairly easy punch a hole in the wall and patch job. The only positive is that it is hot water which I can live without temporarily (turning off the heater and turning on only as needed) but can still at least have cold water.
: What I am confused about is this page:
: http://www.terrylove.com/watersize.htm
: The water meter at the street is 3/4" and the supply to my house is also 3/4". According to that page, I shouldn't have enough to supply my two bathroom house, which incidentally has the exact number of units which Terry describes (34). If I'm to believe that chart, I should only have enough water to supply 19 units. If I'm thinking right, I should be okay since the only problem would be if all of those 34 units were turned on at the same time (never happen). But the other wrinkle is what about when the lawn sprinklers are turned on?
: The other thing is the yellow box which states that 1" CPVC is equal to 3/4" copper and 3/4" CPVC=1/2" copper. I trust Terry's info but I was told otherwise at the local Big Box center. I just want to make sure before the dust starts flying. (I'm so dreading this, and I have never worked with CPVC .. only copper).
Confused1,
That chart comes right out of the UPC plumbing code book.
If you want to take advantage of the information that plumbers have to live by, fine.
You could take the advice of the non-plumbers at the big box earning low dollars, but then, it is your house.
You could plumb the whole house in 1/2 pipe if you want.
It would never pass a plumbing inspection here though.
These codes are meant to protect the homeowner.
I've never believed in going with the least amount.
I tend to size up to protect the homeowners.
I do better than the chart allows for.
