Re: slow drip inside tank to bowl
[ Follow Ups ] [ Post Followup ] [ Terry's WWWBoard ] [ FAQ ]
Posted by LonnythePlumber on August 24, 2003 at 15:26:49:
In Reply to: slow drip inside tank to bowl posted by Gina on August 24, 2003 at 14:20:33:
: I just purchased an Eljer Toilet and Tank, installed it, and there is a slow drip noise inside tank. I used food coloring to see if the drip was going to bowl and sure enough, it was. All the parts are new, so its not worn parts. I drained the water to just under the hole where the flapper sits to see if it still drips and it does. I put my hand inside the hole and can feel the drip, and can see it, but I don't know where its coming from. Short of taking the tank back - what do you suggest.
Is the water level below the overflow tube? Did you cut off the refill tube that sticks into the overflow tube. If it is below the water level it will siphon water into the bowl. Water into the bowl must come from the flush valve. I do not understand that it still drips with little water in the tank. Try pushing down on the flapper and wait a minute to see if the water stops. The flapper may have dried out. Every few years I do run into a plastic Flush Valve that has a pin hole leak. LonnythePlumber.
Follow Ups:
Post a Followup
Name:
E-Mail:
Subject:
Comments:
Optional Link URL:
Link Title:
Optional Image URL:
