| Posted by lee on August 18, 2003 at 17:11:24: | |
| In response to Re: kohler pressure toilet leak | |
One of my toilets (Kohler Rialto Pressure Lite) has exactly the same problem. Were you able to fix it? Where did you get the replacement parts? Was is a faulty cartridge? : I have a 7yr old kohler pressure-clean toilet that has begun to lose it's pressure. On inspection, I've found water spray coming from the "plunger-post" when the toilet is flushed - this is the valve assembly located in the circular section in the center of the pressure tank. This recessed area also is holding water and I've noticed air(water)escaping from the ring which surrounds the recessed hole where the valve is seated. It appears that there are very small pinlike holes or cracks in this ring, which I believe may be a threaded part to hold the valve in place.? I don't really know of course and the plumbing store where I bought this from was no help. Has anyone had similar problems? Any ideas on locating parts for this product and repair instructions? Thanks for any help.
| There are none. |
