Re: Kenmore Power Miser 9 Gas Water Heater
Posted by sandi on July 25, 2003 at 21:55:31:
In response to Re: Kenmore Power Miser 9 Gas Water Heater
Hello....can you give me an update to your problem? Pls. email at the above address..I am having the same problem, have spent $900 on a system to get rid of it but it is actually worse. I look forward to hearing from you. water has a bad odor, like a sulpher smell. Had our water tested and was told that this is a comon problem and that all I needed to do was remove the anode rod from the unit, cut off the anode rod and put back the screw in cap. I'm reluctant to do that thinking the rod must serve some purpose. What would you suggest?
Replies to this post
There are none. |
