| Posted by Hube on July 21, 2003 at 08:57:08: | |
| In response to Re: Pressure tank and sweating | |
: Pressure tank has a small puddle under it occassionly when the humidity level goes up, is it possible it is because the fittings on the tank outlet are a galvanized elbow leading to a galvanized union then to p.v.c. pipe or do you think it would be a leaky fitting joint. : Thanks Randy The condensation can be cured by wrapping a fibre glass blanket around tank. Use the blanket that has the shiny foil wrap on the outside. You only need to go up about 3/4 of the tank heigth. Hube |
| There are none. |
