| Posted by hj on June 22, 2003 at 16:36:46: | |
| In response to Re: Commercial carrier installation-need help fast | |
Why did the plumbing fail? Installing a wall mount toilet can be difficult if you do not know the proper routine. If it is installed improperly, the toilet can crack when it is mounted or when it is used. Why isn't the plumber doing the correction? : I am an owner of a family entertainment center that was scheduled to open 2 weeks ago. We have failed our final plumbing inspection. We flushed the pipes and found no leaks. The walls that the carrier is on is green board drywall and they are not very straight. After pulling a couple of the toilets off, we noticed some of the seals were pinched. There are washers that did not come with the orginal order that the manufacture says should of came with. We need help fast, we have a $2 million dollar investment and can't open our doors. Any insite would greatly be appreciated.
