: I recently moved into a 40+ yo ranch. Am concerned about the outside supply line. Is there any way to tell if the supply line has been replaced? I see no sign of where a trench may have been dug but would assume that if the pipe had been replaced say 5 years ago I wouldn't necessarily notice anyway. Thanks for any help! WHAT is your concern about? are there signs of corrosion particles at the taps? Are you on municipal hook-up? and if you are, then let them look after the line. Ask them. If your on a well system the supply line could be ABS (will outlast you & i)
