Leaking brass to PVC conection under Tub
Posted by Don on June 10, 2003 at 04:14:22:
I am replacing my tub and can't stop the leaks aroung the joints that are mating up. I replaced everything as original with putty around the drain. The only thing I can't get to stop leaking is the plastic to brass connection. What if anything can i use as an adhessive to stop that. I know it can't be normal putty do to the placstic nut and seal. Thanks for any help.
Replies to this post
