| Posted by nicktheplumber on June 02, 2003 at 21:55:56: | |
| In response to Re: 3.5 gallon toilet requires 2-3 flushes sometimes | |
If everthing is as you say, I would guess that you have a partially blocked drain pipe and or poor venting. Try snaking the bowl with a closet auger and then snaking the rest of the system. If that doesn't work, call in a good plumber. NtP |
| There are none. |
