| Posted by Les Thompson on May 25, 2003 at 13:22:26: | |
| In response to Re: Problem with hot water supply | |
: There is no "vacuum in the system". The plumber was just giving you a fancy explanation for a simple adjustment. WIthout access to the unit we cannot tell if it is a circualtion or control problem. Most other plumbers should be able to check it and find the problem, if they are familiar with indirect water heaters. ok, do you live near Massachusetts? :-) |
