| Posted by Hube on May 03, 2003 at 07:21:10: | |
| In response to Re: low water pressure | |
: We have a well and have trouble getting a reasonable amount of pressure in the faucets, mainly the ones downstairs....any sugesstions? With out much info its hard to define the pressure problem. What was the tank pressure reading,(cut-in...cut-out)? usually 30-50 is sufficient, but this is adjustable at the control. Check the valves to make sure they are open full at the points in question. Check any areators for clogging,etc. Hube |
| There are none. |
