| Posted by poorplmbr on March 23, 2003 at 22:28:15: | |
| In response to Re: outdoor faucet | |
: hooked up my garden hose to rinse off the patio...low water pressure. went back to check the hose connection and what do you know, water is running out BETWEEN a couple of bricks below the faucet. : the pipe to the faucet is accessible in the basement and it is okay up to the wall, so somewhere between the inside wall and the outside brick i have a problem. how do i figure out what it is and how do i fix it. Chances are you've had a freeze up during the winter and the pipe split..only way to fix it is to remove the pipe and replace it. |
| There are none. |
