| Posted by Mark on March 22, 2003 at 00:32:35: | |
| In response to Re: Help! How do you dissolve/remove CPVC cement? | |
Try this: Cut the elbow off the pipe with a hacksaw - make sure you leave 3/4 inch. of the elbow on the pipe when you cut it (the glue joint part). Now, with a hacksaw blade or a "tiny tim", make a cut (perpendicular to the first one) on the thickness of the remainder of the elbow (without cutting the pipe). Make 4 cuts (at 12, 3, 6 and 9 o'oclock on the pipe diameter). Now, wedge a flathead screwdriver in each cut and twist. If the joint is relatively fresh (1 to 2 days), the remainder elbow "ring" should snap off the pipe. Phew!!!! That was hard to put into words...
