You put in a ceramic tile floor or order a man made marble base. Lonny the Plumber.
I've recently removed my old 1-piece corner shower assembly because it had begun to crack. The drain pipe is located at 16+1/4" and 17+1/4" from the studs of the two walls. I would have thought that there would be a standard to this but I am now finding it difficult to find a replacement shower pan in which the drain pipe will line up with the pan drain hole. What can I do?
