| Posted by hj on January 28, 2003 at 10:59:24: | |
| In response to Re: RE: Toilet Flange PVC | |
I do not know how you could do that since most flanges are no more than 3/8" thick already. : I have a 1 piece toilet flange that if attached, ie (set onto the pipe sticking out of the floor), would be about 3/8 too high, thus the flange would be sitting off the floor. There is no way to lower the pipe elbow, and the riser if you will is already short enough in relation to the elbow. I plan to cut a small slice off the bottom of the 1 piece flange to make it fit and sit flush on the floor, is this ok to do?
| There are none. |
