| Posted by David Robinson on January 13, 2003 at 20:27:26: | |
I have 120 psi coming in from the city's water system. I have a regulator on the main line set to 65 psi. I put a gauge inside the house and found the static pressure is 120 psi but when you turn on a faucet the pressure drops to 65 psi. Is this normal or is the regulator messed up? |
