| Posted by tom on December 23, 2002 at 22:31:55: | |
| In response to Re: Installing a pedestal sink | |
: I have the same sink and my house was built in the same time period. I just put it on the wall yesterday... : You should definitely bolt the sink into the tile wall, but I doubt that you will need the 2X4 - here's why: I think the 2X4 install tip is for new construction. IN other words, behind your tile is most likely NOT drywall or greenboard. It is most likely a mud or mortar wall. : Look at your access panel for the shower and you should see metal and something like concrete coming thru it. If this is the case you have a pretty sturdy wall to drill into and bolt the sink too. They sell special tile bits, be careful drilling the tile! Use an anchor as well. : The base itself definitely will not hold that sink up... The base should probably be bolted into the floor but mine isn't.
