| Posted by Waxer on November 23, 2002 at 21:07:16: | |
I see that my bathroom sink leaks from the threaded chrome pipe as it goes into the bowl through the brass fitting from below :(. I removed the ptrap section leaving only the chrome tube. I attempted to tighten the pipe a bit but it turns the drain at the same time. Is there a way to tighten the pipe and keep the drain from turning? Maybe I should loosen the pipe completely and then use the plumbers tape and then retighten with new plumbers tape. Thanks for the advice, Doug |
| There are none. |
