| Posted by Casman on November 07, 2002 at 09:15:51: | |
| In response to Re: Leaky plumbing behind bathtub?? | |
: I have a tri-level and there is a leak from the ceiling vent/fan cover in the lower level bathroom. It drips occasionally, sometimes heavy. Directly upstairs is a bathtub and the tub faucet leaks (a little drip). If the downstairs leak continues after I fix the faucet...Where do I start to look for the problem?? Please give me some direction. : Thanks. : Dan : Lansing, MI Well from your description, if its not the leaky faucet then you should power down the vent fan take it apart to allow you a vantage point to locate the leak, whether from the tub drain or elsewhere....good luck... |
| There are none. |
